Converging process
Old   May 26, 2015, 09:56
Unhappy Converging process
hosna
e.abedini is on a distinguished road
hi everyone
which one is more important in converging process? residuals or stability of residuals?
for example our continuity residual is considered 10e-6, after some iterations , the residual reaches to 10e-6. Is this residual enough for stopping process or we have to continue iterations to reach stability?
e.abedini is offline   Reply With Quote
Old   May 26, 2015, 16:17
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
residuals monitor the change between sucessive iterations. when the residual is very small it means your solution is not changing, its a mathematical convergence but to deterime if you have obtained a correct physical solution you need to look at more information.
edoan is offline   Reply With Quote
continuity, iteration, residual, stability
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 09:42
Problem running in parralel Val OpenFOAM Running, Solving & CFD 1 June 12, 2014 03:47
error 262144 and unexpected disconnect when run on 2 nodes Emily1412 SU2 Installation 1 April 10, 2014 18:08
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 16:15
Fluent coupled with external process Nitesh Goyal FLUENT 0 July 10, 2007 10:35
