I Need Source Code for 2D Incompressible Flow
Old   June 20, 2008, 11:33
Default I Need Source Code for 2D Incompressible Flow
Allan
Please,
I am trying to implement the SIMPLE method of Patankar in a half staggered grid, but unfortunately, I can not find where the mistakes in my code are. I am using a central difference scheme in the convective terms. I would like to know where I can find a source code of a 2D incompressible flow implementation?
Old   June 20, 2008, 11:46
Default Re: I Need Source Code for 2D Incompressible Flow
Praveen. C
Look here
http://www.cfd-online.com/Wiki/Codes#Free_codes
Old   June 20, 2008, 11:47
John
Peric code is the best for educational purpose,
you could download it from: ftp://ftp.springer.de/pub/technik/peric/peric.tar.gz
good luck
Old   June 20, 2008, 11:51
Allan
Many Thanks.
Old   June 20, 2008, 20:18
CDS
do not use central difference to start with. Use upwind first , when you get results with it, then switch to central differencing. your code probably is unstable because you are using CDS
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
I'm looking for a flow solver (source code) Steve Collie Main CFD Forum 2 January 26, 2001 13:24
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
