Self-similar solutions
Old   June 9, 2008, 16:20
Default Self-similar solutions
wi
What is Self-similar solutions? Any online notes or books please..........
Old   June 12, 2008, 13:01
Default Re: Self-similar solutions
Paolo Lampitella
The similar solutions (this should be the right name) are solutions that are invariant under the proper scaling of the independent variables.
Some example are the round jet and the blasius profile, both solutions of the boundary layer equations.
In this case, if x is the axis of the jet or the direction of the wall and y the transverse direction, the two solutions are costant with x / h(x) with h(x) the scaling function and so a single solution of the form f(y) exists and is valid for each x / f(x).
Several books exists on similar solutions; actually every boundary layer section should, at least partially, contains some informations about it.
hope this helps
Old   June 12, 2008, 23:25
Bignose
Scaling, self-similarity, and Intermediate Asymptotics by Barenblatt.
How to speed up the simulation of a large amount of similar steady state cases tss Main CFD Forum 4 November 5, 2010 15:36
multiple solutions using Fluent Hanjie Lee FLUENT 3 August 15, 2006 18:21
Analytical flow solutions Antonio Main CFD Forum 0 December 14, 2005 16:43
Analytical flow solutions Antonio Main CFD Forum 0 November 15, 2005 18:47
Blasius Solutions Devin FLUENT 0 October 22, 2003 14:04
