Double precision does not converge, Single precision does
Old   May 7, 2015, 09:16
Default Double precision does not converge, Single precision does
Jan Michielsen
jmmichie is on a distinguished road
Hi all,
I'm doing a crosswind analysis of a train and have found the following problem.
When solving with the double precision solver, my monitored coefficients such as lift, drag, ... do converge after some iterations, however my scaled residuals get stuck at 1 e-02 (continuity only).
When solving with the single precision solver, my residuals have no problem dropping below 1e-05, but the converged values of lift etc. differ somewhat from the ones found with double precision.
I know double precision normally is the more accurate, but can I conclude this when my scaled residuals of continuity get stuck at 1 e-02??
Thanks in advance,
jmmichie
PS: I'm using the k-omega turbulence model and wall functions (y+30). I have tried using y+=1, where the scaled residuals where somewhat less but they got stuck at 5 e-03.
jmmichie is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 04:34
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
what's wrong about my code for 2d burgers equation morxio Main CFD Forum 3 April 27, 2007 11:38
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
