CFD product for wind engineering research
Old   June 3, 2008, 22:03
Default CFD product for wind engineering research
Amer
Can anybody telling me the best cfd software for wind engineering research (such as FLUENT and CFX)
Old   June 4, 2008, 15:42
Default Re: CFD product for wind engineering research
Sam
STAR-CCM+
Old   June 5, 2008, 12:18
Rudresh
Clearly specify, for which application you need the CFD solver.Is it for simulationg the winds/ wind turbine rotors.
Old   June 6, 2008, 13:28
John Parry
Depends very much on what you want to do with it, what kind of processing power you have at your disposal and the depth of your knowledge of CFD. EFD can handle rotating fans and external aerodynamics.
Old   June 6, 2008, 17:02
Balduin Bankerotti
EDF can handle "steady state" rotating fans using "multiple frames of reference".
What about the dynamic load when the blade is passing the tower?
Old   June 7, 2008, 07:14
Amer
Actually, i'm totally new to CFD. Know nothing, but my research in civil engineering dealing with wind induced motion for tall building.....
Old   June 7, 2008, 12:40
Alex
and what do you mean by external aerodynamics?
Old   June 9, 2008, 10:05
John Chawner
Amer:
The Applied Research Group at Intelligent Light (makers of FieldView) has significant expertise in wind turbines. I suggest you contact them. See their web site, www.ilight.com.
Old   June 9, 2008, 19:01
Default Re: CFD product for wind engineering research-----
Adrin
Again, it's not exactly clear what you want out of this research. But based on the short description, I'd say this is a Fluid-Structure Interaction (FSI) problem and not just a simple "steady state" CFD (of course it depends on the flow regime and the building structure). Is this a MS or PhD project?
adrin
Old   June 15, 2008, 23:21
Amer
PhD..but my problem is my self and my supervisor also not really known in this field, that why i'm stress now. Yes wind(fluid) structure interaction. The reason i send here is because to buy the software.
Old   June 15, 2008, 23:24
  #11
Amer
thanks
Old   July 16, 2008, 02:27
  #12
sam
GridPro gives the best grids possible for Wind turbine blade design,and it can be automated.
Old   July 30, 2008, 06:33
  #13
Aero75
Hi Sam,
Sounds interesting. Can you show an example of a mesh around a wind turbine rotor?
Best regards
Aero75
Old   July 30, 2008, 10:02
  #14
Sam
Hi ,
I can send you a ppt of the grids if you can give me you email id and your details.
sam
most recent research area in CFD omr Main CFD Forum 0 March 11, 2005 03:33
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 18:25
CFD Codes Jonas Larsson Main CFD Forum 5 September 14, 1998 08:08
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 3, 1998 09:45
