Turbulence intensity - cross wind on a body
Old   May 4, 2015, 04:44
Default Turbulence intensity - cross wind on a body
Fabio Malizia
Fabio88 is on a distinguished road
Dear all,
I am studying the external aerodynamic of bluff bodies (e.g. car) in case of cross wind. Software used is Ansys Fluent.
The geometry I used is placed inside a cylinder (its external surface is an interface with the external part of the domain), which I rotate to get the proper angle I need.
In case of zero cross wind I use a very low turbulence intensity (0.02%, in agreement with a wind tunnel test I found). However in the presence of cross wind this value I guess is not correct since the wind will have a certain content of turbulence energy inside, that can affect the flow dynamics.
My approach was to assume a turbulence intensity of the cross wind to 5% for each angle case, and insert as b.c. this value scaled with the resultant speed:
I=\frac{5\% V}{\sqrt{U^2+V^2}}
where V is the cross wind speed and U is the velocity of the body.
The result is a turbulence intensity that grow increasing the angle of attack (i.e. it increases with the increase of the cross wind influence on the flow).
I guess this approach a quite simple one but my fear is that it can not be realistic.
I found few papers about cross wind studies but I never found a description of how they set up this b.c.
Do you have any suggestion about the approach I should use or any reference about it.
Thanks for any help you can provide me.
Best regards,
Fabio
Fabio88 is offline   Reply With Quote
Wind load on surface => Turbulence modelling pz1337 CFX 3 March 7, 2012 18:07
Turbulence intensity Visser Main CFD Forum 2 July 12, 2005 07:43
Turbulence Intensity Luis FLUENT 2 June 28, 2005 15:29
turbulence intensity co2 FLUENT 2 December 27, 2003 19:41
turbulence intensity l.g.patil FLUENT 0 February 8, 2002 13:18
