CFD analysis of a heat transfer problem
Old   May 2, 2015, 06:35
Default CFD analysis of a heat transfer problem
Rajeev Kumar Singh
vinitraj3 is on a distinguished road
Hello All
I am trying to solve a simple heat transfer problem. Geometry consists of a cuboid (solid domain) with a pipe (fluid domain) running through it in centre. Four walls of cuboid are given a temperature 1273 K and pipe has inlet and outlet for flow of water. I am trying to simulate heat transfer from heated surface to solid-liquid interface and heat taken inside water channel. I could not simulate this a no heat transfer is happening between solid-liquid interface.
I tried solving conjugate heat transfer also by giving shell conduction at interface wall, but it also did not work.
Please help
vinitraj3 is offline   Reply With Quote
Help needed in using wall BC for heat transfer analysis of heat exchanger tubes hassaan FLUENT 2 June 25, 2013 08:05
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
