Boundary conditions for Boundary layer + pressure gradient |
May 2, 2015, 03:20 |
Obad
Rep Power: 13 |
Hi guys,
I'm currently writing a code to solve the laminar boundary layer equations over a flat plate for an arbitrary pressure distribution. To validate my code I compared my results with the solution of the Falkner-Skan equation for incompressible boundary layers with pressure gradient. I compared the velocity profiles at different axial positions on the flat plate. In the front the numerical results seem reasonable but further in the back the results diverge. I attached a graph that shows both the numerical and the Falkner-Skan results, these results are with a favourable pressure gradient. My code works fine for flow without pressure gradient and for flows with a moderate pressure gradient the results are good. But as I increase the pressure gradient (more favourable) the numerical results start to form a "bump" in the middle. I use a rectangular grid and at the upper boundary I specify the u-velocity distribution as it is given by the pressure gradient and set the gradient of the v-velocity to zero. Does anyone have a clue what could cause this problem? Cheers! |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
