IGES/IGS format geometry file for icem meshing
Old   May 27, 2008, 19:24
Default IGES/IGS format geometry file for icem meshing
littlelz
I am trying to import the igs geometry file into ICEM for generating mesh. I am just wondering if the iges/igs file exported from CAD package can be used directly for icem meshing. I use' buid topology' to check the geometry quality, it seems all right, there is no hole/gap in the geometry file. But I still think the surface is not smooth enough for meshing. Do I need to clean it up (like regenerate the surface) anyone has the similar experience? any idea on it!
Thank you very much in advance
littlelz
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 18:33
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
