Simulation of convective heat loss from cylinder
Old   April 27, 2015, 07:07
Default Simulation of convective heat loss from cylinder
buidu
buidu is on a distinguished road
Hi all,
I am running a simulation with flow passing a finite cylinder in order to get the overall covective coefficient of the cylinder.
Unstructural mesh was adopted for the calculation domain, and the elements near the cylinder is much denser than other parts. The distance of the inlet, top wall and downwall to the cylinder is 5 times of diameter, and the distance of the outlet to the cylinder is 10 times of diameter.
I ran the simulation with inlet air velocity of 0.2 and 3m/s using RSM model in steady condition.
Comparing with empirical euqation that calculating the Nu number, the result agree well in lower speed but much higher overestimated in case of 3m/s, around 20%.
Does anyone knows how should I improve the calculation result. Thank you very much!!!
Regards,
Hao
buidu is offline   Reply With Quote
Old   April 27, 2015, 12:20
Lane Carasik
lcarasik is on a distinguished road
Did you refine your mesh with increasing speed/Reynolds number?
lcarasik is offline   Reply With Quote
Old   April 28, 2015, 03:57
buidu
Hi Lane,
I did not refine my mesh. But I checked the Y+, they are below 1 in all the speed on the surface of the cylinder.
Hao
Old   April 28, 2015, 04:02
Lane Carasik
What wall treatment are you using?
Old   April 28, 2015, 04:53
buidu
I used the enhaced wall treatment, the calculated Y+ were all below 1 at varied speeds.
Old   April 28, 2015, 04:58
Chris_321's Avatar
Christian
Chris_321 is on a distinguished road
I think you need to refine further downwind.
Make a cutplot of the velocity with visible mesh.
Chris_321 is offline   Reply With Quote
Old   April 28, 2015, 05:10
Marion
cymbourne is on a distinguished road
Which heat-flux model are you using?
And I agree with Christian, you need to refine your mesh downstream
cymbourne is offline   Reply With Quote
Old   April 28, 2015, 05:55
buidu
Yes, I will have a try. But why the wake will affect the convection on the cylinder?
I think the turbulence intensity will also affect the final result. When I ran with TI in 5%, it can convergence very well. However, when I reduce the TI to 0.1%, it showed that the turbulence viscousity ratio exceed 100000. You can see the contour in attachment. The high ration zone happened in front of and behind the cylinder. How do you think I should solve this problem?
Thank you.
Old   April 28, 2015, 06:02
buidu
Thank you. I will do that. But do you think the turbulence intensity will also affect the results. I tried to run the case in low TI. However, the turbulence viscosity ratio reached its limitation in the zone near the cylinder. Do you think if I need to change other parameter of setting besides refine the mesh?
Old   April 28, 2015, 08:11
Chris_321's Avatar
Christian
Check the visosity ratio after refining your mesh.
Regards
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
New guy trying to solve his first simple Heat Transfer simulation. BhaluBear OpenFOAM 2 August 12, 2014 13:54
Writing a UDF for heat loss from a composite wall mali28 Fluent UDF and Scheme Programming 6 January 15, 2012 10:27
loss calculation in simulation of turbomachines playmaster Main CFD Forum 0 August 21, 2010 06:59
veriable heatWallFlux / heat loss Shoonya OpenFOAM 1 July 16, 2010 19:10
