Export CFD Solver results to text file format |
May 22, 2008, 20:17 |
I'm a computer graphics student and did some CFD simulations at the university lab with a software called UGS NX5. I used the Advanced Simulation Environment and did a Flow simulation for external air flow around an obstacle. Everything works fine so far, but I'm a bit lost about exporting functionality. As my purpose is to visualize the results myself, I need to be able to read the solver's results. Does NX5 allow such an operation? Ideally, I would get an .XML or .VRML file containing the results. Can you help me out? I assume that portability of such data is not intended by the software manufacturer, however I'm sure I'm not the first person trying such a thing. I'd love to hear hints or even recommendations about other CFD software that writes into open file formats. Regards Maik |
May 22, 2008, 20:39 |
Re: Export CFD Solver results to text file format
I'm not familiar with the CAD software market. I did check the website and found a pretty drastic warning about 'piracy'. Since you're in a university, the university should have a license and - support from the company who sells the software.
Have you asked the company how to get the output you need? |
May 23, 2008, 02:34 |
no I haven't asked them, but that's a good idea. I'm going to do that. Thanks |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 07:43 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
