April 26, 2015, 08:52 |
Pressure field in mixed convection
shahrooz
Rep Power: 15 |
Hi, I have written a code to simulate fluid flow inside a vertical channel using SIMPLE algorithm, everything was ok until I added buoyancy forces ( (rho_infinity - rho) * g * Volume) to y_momentum equation. after doing so the code converges but the pressure field does not seem correct to me since it has lower values in inlet than outlet.
considering I have set velocity inlet boundary condition (v_in = 0.01 m/s) I expect to get higher pressures at inlet than outlet. after some investigation I found that the reverse pressure gradient is equal to hydrostatic pressure field of the fluid but in reverse direction. Any comments are appreciated. |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 11:08 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 18:16 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 17:29 |
pressure BC-natural convection | engahmed | Main CFD Forum | 0 | June 16, 2010 12:38 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
