Rep Power: 0 ![]() |
I am trying to simulate the heat flux of a heat exchanger with forced convection. It consists of cylindrical tubes in crossflow which are positioned in line. The distance between two tubes is 5x diameter For one case the Reynolds number for the flow around the cylinder is Re = 750. For a second case it is 200. My question is if I should use a turbulence model or simulate a laminar flow. As far as I know the wake would be turbulent. So the influence on the next tube is significant. |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 11:37 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
