difference between ideal gas & boussinesq approach
Old   May 18, 2008, 19:44
Default difference between ideal gas & boussinesq approach
meda
Dear all, I want to study natural convection in enclosed spaces. In what cases should I use Boussinesq or Ideal gas approach? Which one is more accurate?
Thanks in advance
Old   May 19, 2008, 07:01
Default Re: difference between ideal gas & boussinesq appr
Vinayender
Natural convection flow are generaly low speed flow and hence we solve such flows with an Incompresible flow approximation. But Imcompresible flow approximation indicates density is not a function of pressure and temperature. But denstiy varation in Natural convection flows depends on temperature and Hence we incoperate this effect in Incompressible flow solvers that density varies with temperature (which is called as boussinesq approximation) by including buyoncy terms in momentum equations in addition with relation between density and temperature.
Thanks, Vinayender.
TO all :- Please correct this if I am wrong somewere..
Old   May 19, 2008, 08:12
meda
Thanks a lot Vinayender.
Meda
Old   September 15, 2020, 15:53
Sai Krishna
Sai Krishna is on a distinguished road
Originally Posted by Vinayender
;55188
Thanks, Vinayender.
i think incompressible means we neglect density variation with pressure only. not with temperature
Sai Krishna is offline   Reply With Quote
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
incompressible ideal gas denise Main CFD Forum 0 May 22, 2010 12:40
difference between ideal gas and incompressible? Ric Main CFD Forum 1 March 24, 2007 13:07
question about ideal gas thermal flow yong Main CFD Forum 0 January 7, 2006 00:58
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
