May 9, 2008, 19:36 |
negative density/pressure
I am calculating external air flow around airplane. I got the negative density/pressure error message as the Mach number=0.768. The calculation crashed. if I change the mach number to 0.125, the calculation can get through. what's the problem? which direction I should go? mesh? solver?
many thanks |
May 10, 2008, 12:09 |
Re: negative density/pressure
I think there is definitely something wrong with your solver code. Which method/scheme did you implement?
May 10, 2008, 17:07 |
actually, I don't know because I am using a research code. I don't know much on it. I do know it is using RANS method for turbulence modelling. are you sure there is nothing wrong on anything else. many thanks for your reply.
May 12, 2008, 04:07 |
Thats the sign of diverging. Better run with less CFL or change your grid (make it little more courser). Thanks, Vinayender. |
May 12, 2008, 18:24 |
thanks, Vinayender.
how less of the CFL is your recommendation? do you think the mesh should be coarser, it seems there is shock for high mach number. am I supposed to refine the mesh? what's your point |
May 13, 2008, 01:36 |
Who much CFL ??... that you can get by trial and error. If you dont want to change the coursen the grid then better use more dissipative schemes in your code. One more sugesstion, better know about the code that you are using, that will help you out to figure whats the problem could be !!!!! Thanks, Vinayender. |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 03:39 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Contour plot with negative velocity | J | CFX | 11 | November 3, 2008 17:46 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
