Flow Around four cylinders in square configuration |
April 12, 2015, 17:13 |
alper yıldırım
Rep Power: 12 |
Hello friends,
I am working on a problem for a long time. but I am having problems with the results. I would like to hear your views on this subject. I briefly describe the problem: 4 square cylinder placed in square condition. 1 and 2 of the cylinder's front. 3 and No. 4 cylinders behind. y + = 1 and k-omega SST model is used. time step size is 0.002. Re = 8000. results true for cylinders 1 and 2. but I get an error in the range of 50-80% for cylinders 3 and 4. I've got two pieces of mesh. screenshotts is down. (inlet and outlet are shown opposite) The green example: Calculated Cd value lower than the value that should be, Purple in color example: Calculated Cd value higher than the value that should be read. Waiting for your help in order to establish the correct model. thanks |
April 13, 2015, 17:44 |
Matt
Rep Power: 18 |
Your photos are not visible.
Can you share what you are comparing your results against? How do you know the aft cylinders are off by 50%-80%? |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Flow around two tandem cylinders | shantanukale | OpenFOAM Running, Solving & CFD | 5 | May 30, 2014 10:00 |
Modeling of flow inside 2D square s/c | peter.pan | Main CFD Forum | 0 | April 11, 2014 02:19 |
Secondary Flow in Square Duct | YJ Lee | Main CFD Forum | 7 | October 13, 2012 01:49 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
