whistling through a pipe
Old   April 21, 2008, 20:21
Default whistling through a pipe
cfd-student
Hi guys
I wanna whistle through a pipe and analyse the acoustical behaviour. What sort of boundary conditions i would need to do that. How much pressure do you recommend I should apply at the inlet.
Can you please direct me to any reading material on the subject. Thank you
Old   April 22, 2008, 13:33
Default Re: whistling through a pipe
Tim
Interesting question. You suck a lot more powerfully than you blow. I think that humans can draw about 5" of mercury vacuum, and blow about 1/2 psi pressure. Haven't blown on an anemometer lately, but a velociy boundary condition on the order of 1 m/s seems about right also.
Old   April 22, 2008, 17:15
cfd-student
Thank you tim. I was thinking I should have pressure inlet at the inlet and specify a value for pressure. I am totally confused. How do I whistle through pipe guys??
Old   April 23, 2008, 08:14
Tim
If you have a need for pressure inlet, but do not know the pressure, you could run a test case where you specify the velocity and calculate the pressure drop.
Old   April 23, 2008, 11:53
cfd-student
true. Thanks tim
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 23:14
whistling through a pipe cfd-student CFX 6 April 24, 2008 06:30
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 10:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
