Ricardo Wave Water Injection Simulation
Old   April 2, 2015, 13:20
Default Ricardo Wave Water Injection Simulation
Matt
randomspeedfreak is on a distinguished road
Hi all,
I am currently creating a final year project on 'Water spray injection into turbocharged internal combustion engines'. I am investigating the effect on many aspects of efficiency, heat transfer, burn rate, emissions, knock resistance, turbo and cylinder temperatures when injecting water, or water vapor into the inlet of the engine. Later on I will try to learn to use VECTIS to model the heat transfer within the cylinder, but for now I need to evaluate the effect of water Injection on the temperatures at various points within the system - for this task I am using Ricardo WAVE (despite being relatively new to the software).
One of the variables I am looking to evaluate is the location of the water injection, and what results could be obtained at various points (before cylinder, before turbo, before inlet etc.) as well as the amount of water injected, the temperature of the water, and the duration of the pulse. Therefore I am trying to use a fuel injector and create a depiction of water as a fuel within wave.
I have recently, however learned that WAVE cannot compute this procedure, and the update to allow it to do so is due 1st May - two weeks after my project deadline!
The only other feasible option I can see is to change the composition of the air being drawn in, but this will not leave me a range of results investigating anything near what I am looking to examine.
Anyone have any better ideas?!
Any help gratefully received,
Matt
randomspeedfreak is offline   Reply With Quote
Pressure for wave height in an Water Wave Tank Cluain CFX 8 December 6, 2021 04:58
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
Wave simulation using OpenFoam Ellie OpenFOAM 2 August 30, 2013 03:10
Injection of water in vapor SimoneTecnoil FLUENT 0 November 10, 2009 10:32
Free surface water wave profile John N. FLUENT 0 February 2, 2009 17:17
