April 2, 2015, 10:48 |
finite element programming tutorial
I am new to this site and it might therefore not be the best place for this question.
I have been using finite element software for some time now solving CFD problems. Now I want to learn the basics of finite element modelling. It is my experience that you can best learn by doing something yourself, therefore I am looking for a simple online tutorial explaining the basics of programming finite elements. Preferably in fortran or c++. thank you |
April 2, 2015, 11:18 |
shahrooz
Rep Power: 15 |
Finite element is mostly used for analysis of solid objects, however it's used in fluid flow simulations too. so what are you going to do? if you are going to learn fluid flow simulation I suggest you to first learn Finite Volume and Finite Difference methods which are more used.
I don't know anything about FE methods but I can suggest Versteeg and Malalasekera book for learning FV. Patankar's book is very useful too. |
finite element method, programming, tutorial |
What is C.V. based finite element method | C-H Kuo | Main CFD Forum | 4 | September 19, 2022 15:06 |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 14:06 |
solver for finite element code. | yosi | Main CFD Forum | 0 | August 12, 2014 18:14 |
[Other] finite element mesh to OpenFOAM mesh | skuznet | OpenFOAM Meshing & Mesh Conversion | 2 | May 17, 2014 13:32 |
Finite element versus volume | heidar | Main CFD Forum | 3 | January 30, 2012 02:13 |
