Calculating the stagnation point of a flow field
Old   April 1, 2015, 02:45
Smile Calculating the stagnation point of a flow field
Thanitha
Thanitha is on a distinguished road
Hi
I have a CFD solution form Ansys cfx. Which contains the location data ,velocity vectors along with temperature, pressure, total pressure and data for turbulence modeling. I want to calculate the location of the stagnation point in this flow field.
Is there a specific method to do this apart from getting the point with the highest pressure value? your help is greatly appreciated.
Thank you
Thanitha is offline   Reply With Quote
Old   April 1, 2015, 05:29
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Thanitha View Post
Hi
Thank you
Well, the correct definition of "stagnation point" implies you are solving a potential flow... for viscous flows you have zero velocity everywhere on a fixed wall.
FMDenaro is online now   Reply With Quote
Old   April 1, 2015, 09:30
Thanitha
I don not have the scalar and vector field in function form. Just as point data. Is there a standard procedure to calculate the stagnation point.
Old   April 2, 2015, 18:08
nm
nvarma is on a distinguished road
Create an iso surface with velocity=0.
Or in contour set velocity magnitude max or min to zero. That should work.
nvarma is offline   Reply With Quote
cfx, stagnation point
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 01:37
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 05:59
calculating stagnation pressure uni_student Main CFD Forum 1 January 28, 2011 21:03
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 17:48
