March 31, 2015, 16:21 |
One-way /two way coupling for particle
Rep Power: 14 |
Hello everybody,
I am trying to simulate a flow with particle and a volume fraction of 4,3x10e-4. I just want to know which model I have to use, one way or two way coupling? I make some research and find some different rules, for example that for a volume fraction higher that 10e-6 the two way coupling should be used. Does someone know if this is right? Thanks |
March 31, 2015, 16:32 |
Michael Prinkey
Rep Power: 25 |
It also a function of the relative densities of the two phases. If the solids phase is very dense relative to the fluid phase, even a fairly low solids volume fraction mixture will cause serious changes to the gas flow. Relative velocity of the phases is also potentially importance as the drag force increasely superlinearly with relative velocity.
I am not an expert in this area, but I'd recommend that you look at the momentum equations for the two phases. Throw out all of the terms except inertia and drag and look at the relative magnitude of those terms with representative flow conditions inserted. That should allow you to see which phase is driving the other or if the dynamics of both are coupled strongly to each other. |
April 5, 2015, 04:40 |
Rep Power: 14 |
thanks a lot,
I will take a look at the momentum equation, I think I will have to use the two way coupling because of the high mass loading of my flow (around 100%). |
June 17, 2016, 10:24 |
Shalabh Singh
Rep Power: 10 |
Can anyone tell me how to enable 2 way coupling in Discrete Phase Model, ANSYS Fluent?
October 21, 2018, 15:14 |
Francesco D'Angelo
particle, way-coupling |
FSI problem with system coupling: Fail to couple FLUENT | sophieUNSW | FLUENT | 16 | October 1, 2020 06:20 |
Remeshing_ ANSYS 14.0_ System Coupling | acdesa | ANSYS | 4 | November 2, 2016 10:12 |
Simple Behavioural Models: Fluid Coupling | Chromatix | Main CFD Forum | 0 | February 20, 2010 17:17 |
What is weakstrong coupling in FSI problems | hajo | OpenFOAM Running, Solving & CFD | 5 | May 15, 2008 02:45 |
one/two way coupling of DPM | Angela | FLUENT | 3 | April 28, 2008 10:29 |
