March 25, 2015, 10:42 |
Suitable scheme for node connectivity
Rep Power: 16 |
Hey,
If I wish to connect a set of randomly placed nodes using a five point stencil. It is important to retain the property that if nodeA-->nodeB then nodeB-->nodeA. What methods are suitable for this? I can use a triangular mesh and connect triangle edges into this five point stencil (two connected triangles have 5 edges), but I was wondering if you have any other suggestions. Cheers! |
March 25, 2015, 12:01 |
Michael Prinkey
Rep Power: 25 |
Getting from random space points to a properly connected grid/mesh is a difficult problem and may be impossible under the constraint of a five-point stencil (I'm assuming 2D).
There are 2D paving algorithms that will give you quadrilateral meshes (four-sided cells all with four neighbors) but it is not a trivial process: http://www.researchgate.net/publicat...ne_constraints http://www.imr.sandia.gov/papers/imr20/Mukherjee.pdf But in both of those papers, you start NOT with random points but with boundary points and then the algorithm fills in the domain with points/cells. Triangular mesh algorithm is easier and gmsh can do this for you automatically. |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Is it suitable to use Weller's scheme in this case? | kaifu | OpenFOAM | 5 | June 22, 2011 09:09 |
Poisson Solver or suitable scheme | Tingting | Main CFD Forum | 1 | August 4, 2006 07:47 |
Which scheme is suitable for NS under vacuum? | Zhihang Zhang | Main CFD Forum | 1 | January 21, 2004 20:47 |
Regarding a suitable scheme for BFC | Abhijeet Vaidya | Main CFD Forum | 4 | December 18, 2001 13:15 |
