Learning structured meshing
Old   March 25, 2015, 08:35
Default Learning structured meshing
Deepak Selvakumar
2611dpak is on a distinguished road
I am new to CFD. I want to analyse a flow through a valve. The geometry of the valve is very complex. Hence I am starting to learn from simple geometries like, flow over a cylinder in 2D. I am able to create a unstructured mesh using the inbuilt command in fluent. But I need to create a structured mesh for simple geometries first and then apply that knowledge in mehsing my complex valve. Kindly pls guide me where to start learning structured meshing for 2D and 2D geometries. Pls refer a good guide or a tutorial video.
2611dpak is offline   Reply With Quote
Old   March 25, 2015, 17:40
Daniel Wilde
QCFD is on a distinguished road
What meshing software do you have access to? Structured meshing tutorials will be software specific.
Fluent mesher does not support block structured meshing
QCFD is offline   Reply With Quote
Old   March 25, 2015, 23:23
Default Thank You
Deepak Selvakumar
Thank you so much for ur reply. I have access to Ansys Fluent and ICEM CFD...If required please suggest some useful meshing packages and tutorials also.
Old   March 26, 2015, 07:56
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
the blocking tutorials in ICEM will teach you how to create hexahedral meshes you can use in FLUENT. Fluent will only accept unstructured mesh so when you convert your premesh to mesh (tutorial will show you how) make sure to convert to unstructured.
edoan is offline   Reply With Quote
Old   March 26, 2015, 08:46
Daniel Wilde
ICEM is a good software to use for learning block structured meshing. It comes with some good tutorials to get you started. Just open ICEM, hover over help, and click tutorial manual
Old   March 26, 2015, 12:01
Simm
kulls is on a distinguished road
Yes ICEM CFD is a versatile software to generate unstructured and structured multi block grids ....it can handle quiet complex geometries.
Just follow the tutorial and you, ll learn it.....
Can you share your geometry ...I would like to generate structured grid on it.
Thanks!
Thanks!!
kulls is offline   Reply With Quote
Old   March 26, 2015, 12:05
Daniel Wilde
Thanks!
Is this a standing offer? I have some geometries that need to be meshed
Old   March 26, 2015, 13:27
Simm
Yeah! Definitely.... It will be good for me to try different geometries.. Bring it on please
Thanks!!
Old   March 27, 2015, 01:45
Deepak Selvakumar
Thanks!
Thank u Kulls, I am looking at those tutorials.. I have attached my geometry
Old   March 27, 2015, 05:52
Simm
Hi Deepak
can you send geometry in .tin format or any CATIA v5 format.
Old   March 27, 2015, 05:56
Default Exceeds file size limit
  #11
Deepak Selvakumar
Hi Deepak
I have it in IGS format....But it exceeds file size limit.
meshing basics
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 01:30
CFD Code + partner required + beginner amol palekar Main CFD Forum 1 July 18, 2004 16:32
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 05:49
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
