For a 3-D model, for eg: there is a flow in a pipe or some other structure and there is an obstruction inside the pipe , is there any special method to design it? Method I followed : (solved for velocity profiles) 1. In Gambit, create a face, sweep the face so that it forms a volume1. 2. create an edge, copy the edge along the width of the volume, make a face and then sweep it to form a volume2 (which is the obstruction inside volume1). 3. mesh the edges first, faces next and then the volumes 1&2. 4. Define inlet (mass flow inlet) and outlet (outflow) BCs only as the wall and the continuum entities are default. volume2 is also a wall as there should be no flow through the wall. 5. export the file, read it in Fluent, grid check, K-e turbulence model. 6. mass flow rate at inlet assigned. Material is air. 7. roughness constant,roughness height, k, epsilon are the same default values. No changes are made. 8. solve it. If I follow this method, a. I am missing the borders of the model. b. The flow is straight away, as if the obstruction doesn't exist. Is this the method to run the model? Please suggest me the procedure if I am wrong somewhere. Please help me as I need this to be working. Thank you. rohini. |
1. Better post in FLUENT forum. 2. Define the obstructing object as solid.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
SIMPLE algorithm for variable density flow | mauz | Main CFD Forum | 1 | May 15, 2009 15:13 |
Solve Simple foam for laminar flow | nandiganavishal | OpenFOAM Running, Solving & CFD | 4 | January 20, 2009 00:56 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
simple method for compressible flow | saeed | Main CFD Forum | 0 | April 24, 2003 02:20 |
