SIMPLE algorithm for collocated storage
Old   April 6, 2008, 17:05
Default SIMPLE algorithm for collocated storage
alex
I'm trying to write a 2d FV solver but I can't get the SIMPLE algorithm to work. I get the basics of how it should work but it just keeps adding to the pressure at each iteration until pressure=NaN.
Do you know of a good reference that describes how to code a SIMPLE solver for a collocated, structured grid arrangement. (has to be collocated as I can get it to work with a staggered grid). Preferably written in as simple english as possible!
Thanks
Alex
Old   April 7, 2008, 00:28
Default Re: SIMPLE algorithm for collocated storage
hadian
the difference between staggered and collocated is that you should have correction term for calculating fluxes on cell faces. have you read the paper of Rhie and Chow?
Rhie, C.M. and Chow, W.L. (1983). "Numerical Study of the Turbulent Flow Past an Airfoil Trailing Edge Separation", AIAA Journal 21(11), 1525-1532.
Old   April 7, 2008, 03:20
sudhakar
hi, A very good reference for SIMPLE in colocated grid is the book 'computational fluid dynamics' by ANIL DATE. If you cant get this, you can refer to some of the papers published by the author.
Old   April 8, 2008, 16:36
alex
Hadian, Sudhakar,
Thank you both for your help. The book you recommended by Anil Date was indeed a very good reference. Highly recommended to anyone else interested in SIMPLE for colocated grids.
There is one thing I'm a little unsure of though. In implementing the dP'/dn=0 boundary condition, (on the west boundary for example) I set the west coefficient of the pressure correction to zero. However I still need a value of AW for AP(=AW+AE+AN+AS) (where AW & AP, etc. are coefs. of the pressure correction equation). AW involves ap (ap = coef. of momentum equation) at the west face, which is obtained by linear interpolation between nodal values for internal CVS. How do I obtain ap at a boundary?
Thanks
Old   April 9, 2008, 00:48
sudhakar
hi alex, I think you are little confused. The issue is straightforward. Near the west boundary, aW=0; substitute this in your calculation of aP, then it becomes aP=aE+aS+aN. Once you implement this, you will experience that your iterative solver takes slightly longer time to converge. hope it helps.
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 18:02
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver renyun0511 OpenFOAM Running, Solving & CFD 0 November 10, 2010 02:47
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 04:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 14, 2007 00:17
SIMPLE algorithm Jonathan Castro Main CFD Forum 3 December 10, 1999 05:59
