How to model flow of centrifugal fan?
Old   April 2, 2008, 07:07
Default How to model flow of centrifugal fan?
Peter
Currently I'm working on a flow analysis of backward-inclined centrifugal fan for a customer using Cosmosfloworks. Previously I've done CFD on wind turbine blade using Fluent with Single Rotating Reference Frame where the flow is always rotating and the blades are static.
However, I'm not sure what is the direction of flow in the rotating volume encompassing all the centrifugal fan blades. I know that if I were to simulate the flow over the blades without looking at the entire housing I'll have to make the fluid flowing in the opposite direction of the blade rotating direction. But if that's the case the flow might travel in the reverse direction, outlet to inlet of the housing (correct me if I'm wrong).
I've seen some articles in Fluent website on centrifugal fan and I'm still confused on the flow direction in the moving reference zone.
Please let me know of any guides of tips in dealing with centrifugal fan. Thanks
Lim
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
plotting a performance curve of centrifugal Fan altano CFX 2 October 18, 2008 08:12
Fluent 2D Model - Axial Fan in a Duct J FLUENT 0 April 18, 2006 03:25
Desperate ! Fan model !!! Boris FLUENT 0 January 30, 2003 01:31
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
