Physics of an incompressible fluid
Like Tree24Likes
Old   March 23, 2015, 11:14
Martin Hegedus
Martin Hegedus is on a distinguished road
I gather Jonas might not have understood this
"in you room the closed domain does not permit flow to go in/out from walls. Therefore, the fan must be introduced as an external force in the momentum equation to prevent continuity be unsatisfied. This force, if is not divergence-free acts as source term in the elliptic pressure equation."
statement.
Denaro is correct.
Martin Hegedus is offline   Reply With Quote
Old   March 23, 2015, 11:26
Martin Hegedus
Here is the point that people have been trying to make, the fan provides a delta p, it DOES NOT provide a given velocity.
So, in actuality you have assumed a velocity, then calculate the delta p, adjust the velocity, calculate the delta p, and iterate till you are satisfied.
anon_h and H0T_S0UP like this.
Old   March 23, 2015, 15:16
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
A fan can be introduced by means of a dp/dtheta gradients in the tangential momentum equation. You can decompose this forcing term along the cartesian direction.
See F. Nygard, H. I. Andersson DNS of swirling turbulent pipe flow, Int. J. Numer. Meth. Fluids 2010; 64:945–972
FMDenaro is offline   Reply With Quote
Old   March 23, 2015, 15:52
Martin Hegedus
Do you mean dp/dr?
Yes, the torque from the fan must show up in the flow.
Old   March 23, 2015, 17:09
Jonas T. Holdeman, Jr.
Jonas Holdeman is on a distinguished road
Originally Posted by Martin Hegedus View Post
Do you mean dp/dr?
I don't think torque is relevant. One could imagine a fan with counter-rotating blades, or a grille that straightened the flow.
Jonas Holdeman is offline   Reply With Quote
Old   March 23, 2015, 17:41
Martin Hegedus
Yes, put I don't get the impression that is what is being talked about. We're talking about ceiling fans and disk actuator theory.
Old   March 23, 2015, 17:45
Martin Hegedus
And yes, if we are modeling the individual blades there will be a dp/dtheta.
Old   April 22, 2019, 11:40
Originally Posted by Louise Charlton View Post
Sorry, a little lost here but this sounds like a discussion about potential flow (Panel methods, etc.)
No, potential flows share the divergence-free constraint but you can generilize the topic for more general viscous flows
action-at-a-distance, body force, incompressible fluid, physics
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
derivation for special case for incompressible fluid; condition for v? Simonee Main CFD Forum 0 March 18, 2014 07:56
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
Modeling of free surface in CFD ? Kim TaeMin Main CFD Forum 18 July 16, 2001 12:38
