LES flow through time?
Old   March 28, 2008, 09:46
Default LES flow through time?
kasim
Hi
I am running a LES case on a duct with repeated obstcales inside. I have initialised my case with RANS model. I was wondering how many flow through times (residence time) would I need to obtain converged statistics. What excatly would indiacte that my flow has achieved stability and I do not need to run it any longer. I know its a very basic question but I dont wanna get it wrong. Thank you
kasim
Old   March 28, 2008, 22:07
Default Re: LES flow through time?
Tedy
Hello Kasim, Typically you need about 5-10 flow-through time to obtain a good initial LES solution, then you should run a similar time to accumulate you data for LES statistics. This will give you statistically converged LES results.
Success!
Ted
Old   March 29, 2008, 08:33
kasim
Thank you Ted for your answer. I am collecting statistics in my current run. Do you mean I should disable these statistics and then run the problem with new statistics for 5-10 flow through times.
Kasim
Old   March 29, 2008, 14:31
kasim
One more thing, when I re-start the simulation should I interpolate the existing solution on new run OR should I continue running existing solution and only remove the history from old statistics. Thank you
kasim
Old   March 29, 2008, 15:11
Ted
Hello Kasim,
Yes, you should first run to obtain a statistically converged LES solution (5-10 flow through is an empirical value based on experimenting), THEN you should start accumulating your statistics, that is if you want to look say at your flow mean and turbulent quantities, ex: Ui_av, Ui'_rms, Ui'Uj'_av, etc.
Best, Ted
Old   March 29, 2008, 16:06
kasim
Thank you Ted. In order to collect new statistics should I just disable my current statistics and continue with the LES run OR should I interpolate my existing solution on new run to collect new statistics?
kasim
Old   March 29, 2008, 16:31
Ted
Kasim, Just continue your LES run, and when you consider that your initial LES solution is ok (5-10 flow through's), start accumulating LES statistics. Before you LES becomes fully statistically converged, the statistics you accumulate are more-or-less meaningless. Good luck! Ted
Old   March 29, 2008, 19:41
kasim
Thanks Ted. Have a nice week end.
Kasim
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
LES flow through time? kasim CFX 1 March 28, 2008 14:31
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
Time steps - Large Eddy - LES Gernot FLUENT 0 September 14, 2005 12:54
