Experimental CFD validation
Old   March 10, 2015, 12:01
Default Experimental CFD validation
Stephan_CFD is on a distinguished road
I'm working on a CFD model of a stirred reactor filled with water and want to validate the output (flow profile, flow speed) by comparision with experimental results.
The experimental reactor has proportions that are 1/7th of the modeled one and is filled with water as well. Model reactor has 94rpm, impeller diameter of 1210mm. I downscaled the experimental impeller by keeping original proportions of impeller dimensions and proportion of impeller diameter and reactor diameter. Exp. reactor has thereore impeller diameter of 165mm.
However, for the rotation speed n I don't know how to proceed. My aim is to get a similar flow profile within the experimental reactor as in the original one that is being modeled.
n(exp)=n(model) probably doesn't make sence.
peripheral speed (exp)=peripheral speed(model) results in 690rpm for exp. conditions, compared to 94rpm for model conditions.
The approach I would normally choose is to keep Stirrer Reynolds number constant, Re(exp)=Re(model)
and therefore using
n(exp)*impeller diameter (exp)^2 = n*impeller diameter (model)^2
However this leads to rotational speed of the exp. impeller of 5055rpm,
more than practically can be handeled.
Any ideas how to proceed from here?
Stephan_CFD is offline   Reply With Quote
experimental, model validation
CFD verification and validation Weiqing Xu Main CFD Forum 0 March 3, 2012 09:25
Validation of wind turbine simulations using experimental data of much lower Re Dorit Main CFD Forum 0 March 31, 2010 06:20
validation of CFD results andy FLUENT 0 June 13, 2007 14:55
CFD VALUES AT EXPERIMENTAL POINT J FLUENT 1 September 25, 2005 17:55
CFD experimental validation Massimiliano Gasparetti Main CFD Forum 5 November 24, 1998 08:07
