Mesh in decreasing region between two surfaces |
February 25, 2015, 11:03 |
Christoffer
Does anybody have suggestions how to set up suitable dynamic mesh options for a region between two surfaces which moves closer and closer together, for example the region between a closing valve and its seat. It would be desirable to eventually have no space between the surfaces, however, this would result in infinite small cells.
This is for a project involvning simulation of a closing swing check valve. All suggestions are welcome! /arnbeb89 |
December 9, 2015, 12:20 |
Ramnik Singh
Rep Power: 17 |
arnbeb89,
I am trying to simulate a similar problem where my valve is closing and thus the cell volumes become very small. Just wanted to see if you found a solution? Thanks, Ramnik |
December 10, 2015, 10:27 |
Jonas T. Holdeman, Jr.
Rep Power: 18 |
My first thoughts on this problem would be to reverse the process used in mesh refinement, or maybe consider the restriction phase of multigrid.
December 10, 2015, 12:04 |
Michael Prinkey
Rep Power: 25 |
From my grad school days, I remember KIVA used a combination of stretching and layer removal/addition to handle piston and valve motion. I am fuzzy on the details, but, say, a ten-cell deep mesh (each layer of unit height) would be scaled down until it reached 9 units high...9/10s of its original height, then a layer was removed and the layers were stretched back to all unit height. Then repeat. Eventually you end up with only a layer that one cell thick that you can scale down to zero and then delete it entirely.
EDIT. Looks like they set the last layer to SOLID rather than deleting it entirely. See Section F on Page 14 of this: http://www.lanl.gov/projects/feynman...cs/KIVA-3V.pdf |
December 10, 2015, 18:02 |
Andre Z
Rep Power: 16 |
Just go for the next generation cfd:
https://www.youtube.com/watch?v=qi7rhgZ5A2o |
closing, dynamic mesh, narrow, valve simulation |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[Other] Material properties in multi region foam and refining mesh for each region | mukut | OpenFOAM Meshing & Mesh Conversion | 2 | October 7, 2013 03:08 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
