Solution Does Not Converge
Old   March 5, 2008, 23:06
Default Solution Does Not Converge
Rif
Hi, I'm running an airfoil simulation in Fluent for low reynolds number.I'm using the k omega sst model for transition purposes. My residuals for k and continuity does not go below e-02 and it oscillates around that range. How do i make my solution converge? I have no problems with this when running high reynolds number though. I am using 2nd order upwind.
Rif
Old   March 6, 2008, 02:29
Default Re: Solution Does Not Converge
A.K.
Possibly you've got flow oscillations (buffet) due to the instability of separated boundary layers. What freestream Mach number do you prescribe?
Old   March 6, 2008, 02:52
convergence
I would suggest to do the following. I would create a very very coarse case with same geometry. Will run it with same conditions.(use first order scheme for it). Get some solution. Export the solution to interpolation file. Open the fine grid case, read this file as initial guess. Run first few iterations as first order. Switch to second order.
It should work out.
Old   March 7, 2008, 06:33
Praveen. C
Are you using limiters ? They can stall convergence.
Are your boundary conditions good ? Are the boundaries sufficiently far from the airfoil ?
Try to plot the residuals and see in which part of the flow domain they are high. That may tell you something more about the reason for stalled convergence.
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 08:51
residual plot after solution reset plaunie STAR-CCM+ 1 April 3, 2010 07:53
simple algorithm, converge of solution bbasal Main CFD Forum 0 February 13, 2010 03:58
My Solution wont Converge!!! Chris FLUENT 6 April 16, 2005 19:57
what to do when solution doesn't converge? Jenny CFX 5 January 28, 2004 05:00
