Confusion between 'non-slip' and 'slip' B.C
Old   March 5, 2008, 09:30
Default Confusion between 'non-slip' and 'slip' B.C
jinwon park
For non-slip B.C, the velocities u and v are set zero. For slip B.C, the velocity u(assumed as the normal velocity) is only set zero. Is the solid wall in physics modeled by which one? Ideally, the fluid flow does not penetrate the wall and the tangential velocity may not be disappeared. In these cases, we can say that the wall is a slip-boundary condition. I would like to ask you all about the distintion between the use of 'non-slip B.C and 'slip B.C'. The objective of this equation is to find out the way to implement the solid wall in 2-D compressible flow simulations. Thanks in advance!
Old   March 5, 2008, 09:50
Default Re: Confusion between 'non-slip' and 'slip' B.C
john
wrong, this is non-penetrating bc which is applied for every rigid walls. Normal component of velocity on wall is zero, U.n = 0
but for slip/no-slip bc, we work on tangential component of velocity vector, for no slip we have zero tangential volocity and for slip bc we have zero derivative of tangential velocity.
If you work with a coarse mesh, so your boundary layer (near wall) is not resolved due to coarse mesh, slip bc is more feasible.
Old   March 5, 2008, 09:54
jinwon park
If so, when are you using the non-slip B.C to impose the solid wall? Is there any case where the no slip B.C is properly applied?
Old   March 5, 2008, 10:01
ag
No-slip is applied to solid boundaries in viscous flow. It actually imposes a continuity of velocity at the boundary. If the boundary is moving then fluid particles at the surface take on the velocity of the surface. If the surface is not moving then the fluid velocity at the surface is zero.
Old   March 5, 2008, 10:02
jinwon park
I am solving compressible inviscid flows. Is it applicable to my cases as well?
Old   March 5, 2008, 12:07
ag
If you are solving the inviscid (Euler) equations then the slip wall condition is the appropriate condition to apply.
Old   March 5, 2008, 12:27
jinwon park
Thanks ag!
Old   March 6, 2008, 05:56
Tom
Actually for an inviscid fluid the only boundary condition you should be applying is no flow normal to the surface. The no-slip condition arises in a viscous fluid because the equations are higher-order and so need additional boundary conditions.
inviscid wall and slip wall b.c. Shenren_CN Main CFD Forum 0 September 21, 2011 12:57
slip velocity B.C sajad_abasi CFX 0 September 20, 2011 06:45
Slip BC not working properly lfbarcelo OpenFOAM 3 July 15, 2010 10:53
Corner no slip B.C shuo Main CFD Forum 3 February 23, 2010 21:20
slip B.C mohsen Main CFD Forum 3 January 29, 2003 20:54
