February 19, 2015, 01:23 |
Energy containing range in energy spectrum
MMS
Rep Power: 13 |
I would like to know, how to differentiate the energy containing and inertial subrang eduring energy spectrum analysis (E vs k)? In general cases, if the spectrum not follow the ideal trend (say, slope -5/3 is not identical in the curve), so how to demark these two ranges. |
February 19, 2015, 06:02 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
Sorry but your question is not clear ... the k^-5/3 law is the theoretical slope for the particular case of the intertial range for homogeneous isotropic turbulence, followed by the dissipative range (for real fluids) starting at the Taylor microscale until the Kolmogorov scale. Complex turbulent flows do not necessarily obey to such scaling. Please, reformulate your question |
February 19, 2015, 10:09 |
#3 | |
MMS
Rep Power: 13 |
February 19, 2015, 11:25 |
Rep Power: 73 |
if an inertial range exists, you will see it plotting the spectrum...
for example consider the case of the channel flow: at low y+ (close to the wall) practically you see no straight slope of the energy curve, but approaching higher y+ (towards the center of the channel) the inertial range (at high Re_tau) will be present. That means that in complex flows you can have only some region where an inertial range exists |
February 20, 2015, 01:24 |
#5 | |
MMS
Rep Power: 13 |
As you mentioned ealier that most of the complex flow paterns not follow the theoritical trend, so according to me it is important to identify the energy containing range (energy contained low wavenumbers). But how? Looking forward to hear from you. |
February 20, 2015, 04:36 |
Rep Power: 73 |
well, if you use LES the task is more complex....
1) for complex flows you need a local filter widht, that means that in the region where a large inertial range exists you can have a quite large widht but in the other regions you need to practically solve all scales. For example in channel flows you solve the near-walls structures in a DNS-like resolution while the LES filter acts mainly in the horizontal plane. 2) the filter is something that alters the slope of the energy spectrum. For example the top-hat filter introduce a transfer function like G(k)=sin(kh)/kh. Therefore the ideal slope k^-5/3 you see in a DNS simulation, is conversely smoothed in LES at the frequencies where G(k) < 1. 3) doing LES the energy spectrum is totally truncated after the filter wavenumbers, therefore you cannot identify from your simulation all the intertial subrange but only the resolved part. Of course, there is no dissipative range |
February 22, 2015, 10:27 |
#7 | |
MMS
Rep Power: 13 |
February 22, 2015, 12:15 |
#8 | |
Rep Power: 73 |
As I wrote before, only far from the walls you can have tendency to the recover of isotropy |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
LES correlation and turbulent energy spectrum | Fabian | Main CFD Forum | 4 | October 18, 2005 03:04 |
Energy Spectrum | Emad Khalifa | Main CFD Forum | 3 | June 30, 2003 17:03 |
