February 27, 2008, 22:27 |
implementation of agglomeration multigrid
I am currently implementing multigrid for unstructured grids (2d). I had successfully implemented a defect correction technique and obtained a good convergence rate for higher order solutions. Now, I am in process of implementing the agglomeration multigrid technique. I have some doubts regarding the treatment of coarser grids 1) How to determine the grid spacing (h) of coarser grid (arbitrary polygon) ? Or, how to decide the timestep to take in the coarser grid? 2) Restriction operation is done by injection (agglomeration). If I do a linear interpolation for prolongation, will it give a good convergence? Will the discontinuity at the coarse grid affect the convergence in the fine grid? I saw some implicit methods for prolongation. I was wondering if I should put the effort in doing that. 3) In the coarse grids can I have a first order approximation for convective fluxes and second order for viscous fluxes? I guess it would be more stable that way, and permit a relaxes time stepping in coarser grids. 4) Is there explicit algebraic multigrid technique for finite volume methods (without forming a big matrix). If so, can you give a reference? Thanks in advance for your clarifications. Shyam |
LES by Multigrid | mnabi | Main CFD Forum | 8 | July 11, 2009 21:21 |
multigrid | sureshkumar | Main CFD Forum | 0 | June 9, 2006 02:20 |
local timestep for agglomeration multigrid method | Jian Xia | Main CFD Forum | 3 | March 20, 2000 12:20 |
Agglomeration multigrid to solve Euler equations | Jian Xia | Main CFD Forum | 3 | January 11, 2000 19:07 |
Multigrid applied to k-e models | Paulo Zandonade | Main CFD Forum | 9 | May 24, 1999 09:10 |
