High value of vorticity
Old   February 13, 2015, 14:25
Default High value of vorticity
Divyaprakash
Divyaprakash is on a distinguished road
I am doing a simulation of a spoon stirring water in a cup. I Wanted to observe the vortices formed. When I plot the vorticity contours, they range from 0 to 5000 /s (the high values are present on the edge of the spoon), even though the rotation rate i am giving to the spoon is only 15 rad/s. Shouldn't the vorticity be comparable to the spoon rotation rate? What am i missing here. The simulation seems to be right. I have got all the residuals to converge. Please help me out here.
Divyaprakash is offline   Reply With Quote
Old   February 13, 2015, 15:03
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
vorticity generated at walls is the normal derivative of the streamwise velocity which is generally high.
FMDenaro is offline   Reply With Quote
Old   February 13, 2015, 15:15
Divyaprakash
uh.. Can you please explain a bit more in detail. I guess my fundamentals aren't very strong.
Old   February 14, 2015, 05:30
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
You can find the vorticity definition here:
http://en.wikipedia.org/wiki/Vorticity
For a 2D case, you have:
\vec{\omega} = \left( \frac{\partial v_{y}}{\partial x} - \frac{\partial v_{x}}{\partial y} \right) \vec{z}
In the simple case of a flat plate (i.e. velocity aligned with the plate) this becomes:
\vec{\omega} = \left( - \frac{\partial v_{x}}{\partial y} \right) \vec{z}
Now, assuming your boundary layer is 2mm thick and your free stream velocity os 5m/s, you get a vorticity value of 2500 1/s
lovecraft22 is offline   Reply With Quote
Old   February 15, 2015, 14:19
Divyaprakash
Thanks a lot!!
high, rotation, vortex, vorticity
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 13:29
3D vorticity contour shahzad_munir Main CFD Forum 0 May 1, 2014 03:34
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
Vorticity Iso-Surface John Main CFD Forum 0 April 5, 2009 00:10
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
