HOW TO TELL WHERE THE TRANSITION point is?
Old   February 24, 2008, 08:30
Default HOW TO TELL WHERE THE TRANSITION point is?
Rif
How do you see the transition from laminar to turbulence in airfoil flow in FLUENT? In other words, how can i tell where the transition point is?
Cheerios Rif
Old   February 24, 2008, 09:35
Default Re: HOW TO TELL WHERE THE TRANSITION point is?
kasim
Which turbulence model are you using? If you you SST model which is available is CFX you will actually be able to see transition from laminar to turbulence.
kasim
Old   February 24, 2008, 09:40
Rif
I am using the Sparlart Allmarass Model.
Cheerios Rif
transition point caohan FLUENT 28 April 18, 2018 19:53
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 05:59
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
Importance of transition point Tim Franke Main CFD Forum 4 January 28, 2000 12:14
