Inventor - Bug in Geometry: How to Fix?
Old   February 9, 2015, 21:28
Lightbulb Inventor - Bug in Geometry: How to Fix?
Ray
StarCFD is on a distinguished road
Hi Everyone,
I am an Engineering Student currently working on a interior flow visualization project that involves the use of a mannequin. After creating the geometry using Inventor 2015, it appears that there is a bug in extruding sketches. Somehow, a thin plate appeared right around the leg area (in red in the picture), that I cannot seem to get rid of. When I attempt to remove the thin plate by extruding cuts through it, Inventor tells me that no meaningful edits are being made.
Anyone have some tips on how to remove the plate? Is this something that I should fix right away, or would it be easier to fix this in something like ANSYS DesignModeler further down the workflow?
Thanks!
--UPDATE--
Resolved: For posterity, it turns out that cutting perpendicular across the leg can remove the feature that contains the plane. Then it is a simple matter of re-extruding the leg to fix the issue.
StarCFD is offline   Reply With Quote
cut, healing, inventor, mannequin, preprocessing
[DesignModeler] Fill tool - grouping the faces of a complicated geometry? HeikkiT ANSYS Meshing & Geometry 8 July 20, 2016 08:37
Geometry for Confined Circular Jet Greatness FLUENT 0 October 1, 2013 06:04
Export geometry file from ansys mechanical browns6 Structural Mechanics 0 August 27, 2013 17:19
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
[ANSYS Meshing] Help - Meshing 2 Surfaces On A 2D Geometry Ali_M ANSYS Meshing & Geometry 4 March 29, 2011 04:01
