Homogenous Isotropic Turbulence - Initial Conditions
Old   February 9, 2015, 21:13
Default Homogenous Isotropic Turbulence - Initial Conditions
Eduardo Molina
EMolina is on a distinguished road
Hi all.
I have just implemented the detached eddy simulation based on the Spalart Allmaras RANS model in a OpenSource code and I would like to test it in the decay homogenous isotropic turbulence test case, basically the well know Conte-Bellot and Corssin (CBC) experiment.
I have saw a lot of DES papers using this experiment to calibrate the DES Constant and also to evaluate how the numerical dissipation is effecting the turbulence decay.
The first question that arise is how I can create the initial conditions for the conservative variables based on the spectra of the experimental data presented here: http://torroja.dmt.upm.es/turbdata/a...hapter3/HOM00/
As I saw in the original paper of Spalart that after they imposed the initial conditions for the conservative variables, they freeze these equations and let the turbulence equations converge. Next, they start the unsteady simulation if this proper initial conditions.
Any help is appreciated
Eduardo Molina
EMolina is offline   Reply With Quote
Old   April 14, 2018, 06:40
Ehsan
ehsan is on a distinguished road
Hello
Could you please share your isotorpic turbulence case in OF?
Regards
ehsan is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 20:31
Why RNGkepsilon model gives floating error shipman OpenFOAM Running, Solving & CFD 3 September 7, 2013 09:00
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 14:38
