February 21, 2008, 05:04 |
Cell reynolds number and turbulence
I think I'm missing something about the "cell reynolds number".. Is this simply an indication of the calculation stability, or can it be used to infer the flow regime? My problem is the following: I'm running a CFD simulation in which I really don't know whether I'll get a laminar or turbulent regime. Now would it be possible to solve the problem using Navier-Stokes, then consider the Cell reynolds number, and then pass to k-epsilon in the case a turbulent flow is detected? Thanks in advance for any help! |
December 11, 2018, 03:43 |
Have you find the any response for your question?
#2 | |
Mahdi
Rep Power: 9 |
December 11, 2018, 04:13 |
#3 | |
Filippo Maria Denaro
Rep Power: 73 |
It has nothing to do with the type of regime, it is simply a numerical parameter that is locally computed by means of the local computationla grid size and local velocity. It is relevant to assess the quality of the numerical resolution and has also relevance to avoid numerical oscillation with some central scheme. |
Turbulence model for low Reynolds number flow? | Nokadu | Main CFD Forum | 3 | May 26, 2013 12:42 |
Turbulence Model and limitation to Reynolds number | qascapri | FLUENT | 0 | January 24, 2011 11:48 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 10:52 |
Turbulence Model for low Reynolds Number | Muhammad Shakaib | Main CFD Forum | 2 | July 3, 2006 16:42 |
