ICEM meshes inside my wing
Old   February 20, 2008, 15:03
Default ICEM meshes inside my wing
LBRS
Hi all,
I have a very complex geometry in two parts: wing and body (the root of the wing intersects the body). It is actually only a half bird geometry in a box domain.
Strangely enough, I can make ICEM to mesh outside of the body, but it always meshes inside of the wing. It was written in the tutorials that I have to put a LIVE body point where I want the mesh to be, but it didn't change a lot. I tried several meshing setup.
This is a screenshot, but I'm affraid it's not very clear http://documents.epfl.ch/users/s/se/...ages/icem2.png
How could I enforce ICEM not to mesh inside this surface mesh ?
Kindest regards
Old   February 20, 2008, 23:59
Default Re: ICEM meshes inside my wing
A.S.
Delete the blocks inside the wing
Old   February 21, 2008, 04:16
LBRS
"Delete the blocks inside the wing "
You mean removing the cells manually ? I don't know how to automatically select all these cells...
Old   February 21, 2008, 06:47
A.S.
sorry VORFN the block inside the wing, I did it like that
Old   February 21, 2008, 08:02
Charles
I think there is a misunderstanding here .... Moving blocks to VORFN is for a hexa mesh, and I get the idea from the image that he is building a tetra mesh? Main thing is to make sure that your geometry is clean, i.e. if you run Repair Geometry, you should get red curves only, then put a body point outside the bird's body, and have another go. Make sure that the part of the symmetry plane that intersects the body has been removed. In fact, I am almost sure that is your problem.
Old   February 21, 2008, 08:32
A.S.
Charles and LBRS sorry for the confusion, I had always used ICEM-HEXA and advised based on that.
Old   February 21, 2008, 10:09
LBRS
Thank you a lot for the advides. It seems that a cleaning of the geometry (with a CAD software) really helps.
Also, I have moved the wing a little. Maybe there was holes in the wing outside of the body, which caused the problem.
Now it works much better. Thanx !
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 07:50
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 13:51
[ICEM] 3d mesh around a wing using ICEM artemis64s ANSYS Meshing & Geometry 6 September 23, 2011 08:59
Different results from similar quality cfx and ICEM meshes Nick R CFX 3 January 17, 2011 08:48
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
