Setting up a 32bits server with more than 4gb RAM
Old   February 19, 2008, 20:29
Default Setting up a 32bits server with more than 4gb RAM
HSeldon
Hi, Since CFD is Hardware-intensive application, and also I work with fluids I thought that this site would be the best place to ask this: With a bunch of friends, we are planning to buy and old server (IBM Xseries with 8 Xeonīs) in order to run CFD on it. Hereīs my question. If those Xeonīs are 32 bits processors, but that server supports up to 16GB RAM, how I have to configure the OS (linux 32bit) in order to use more than those famous 4GB associated with the 32bits systems? I hope I was clear... Iīll have 16GB RAM in a 32bit system, so can I use the full power of the 8 Xeons and all that RAM?
Thanks a lot and sorry for my argentinian english. P.S: also I donīt want a full explanation. I donīt want to bother you. Just tell me if itīs posible or will be a waste of money.
Old   February 19, 2008, 22:39
Default Re: Setting up a 32bits server with more than 4gb
otd
Your Agentinean English is much better than my Tennessee Spanish! : )
Sorry I don't know the answer to your question. I hope you can do the project.
Old   February 20, 2008, 09:02
HSeldon
LOL! Thank you otd!
Old   February 21, 2008, 12:29
Krzysztof Jagus
You cannot allocate more than 4gb per processor. The advantage of 8 Xeons is that you will be able to run parallel processing (8 nodes). As a consequence available RAM will be split among those 8 nodes.
Old   February 21, 2008, 12:45
HSeldon
More clear than water, thanks Krzysztof. Now I really want to buy that server!
CFD Online Back on Main Server pete Site News & Announcements 0 March 31, 2011 19:14
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Setting up a 32bits server with more than 4GB HSeldon FLUENT 2 February 21, 2008 09:00
Warning 097- AB Siemens 6 November 15, 2004 05:41
Fluent and RAM Speed Allan Walsh FLUENT 6 April 21, 2004 17:08
