Internal, compressible flow problem
Old   February 5, 2015, 07:29
Default Internal, compressible flow problem
Tom Allchurch
Tom_allchurch is on a distinguished road
Hi All,
I am trying to run a simulation in fluent of the air intake for my FSAE car. it has a 20mm restriction which makes the flow transonic and so i am trying to use a compressible air model in FLUENT. I have attached a picture of the part
BCs:
pressure inlet 0Pa
Pressure-Outlet -36000Pa with target mass flow outlet of 0.1kg/s
the outlet values have been generated from my GT power model of the engine. i have used a Hemi-spherical and a cylindrical inlet domain to represent the atmosphere above the inlet.
So far any results which i get are garbage and most of the time the residuals just blow.
Can anyone help? Is there something which i am doing wrong with boundary conditions or something?
Thanks in advance
Tom_allchurch is offline   Reply With Quote
Old   February 5, 2015, 15:14
agd
agd is on a distinguished road
Just so I understand what you are saying - you are using an incompressible model to simulate transonic flow, and you are getting garbage results. Is that a correct interpretation?
agd is offline   Reply With Quote
Old   February 5, 2015, 16:18
Tom Allchurch
Sorry using a compressible model, I'll edit the description now
Thanks
Internal cylinder flow: createPatch problem meng9019 OpenFOAM Pre-Processing 0 February 12, 2014 14:00
Negative density problem. compressible flow Karl Siemens 2 July 10, 2008 17:41
Convergence problem for compressible flow Saad Main CFD Forum 2 June 5, 2005 16:24
transient compressible flow problem (urgent plz) jehanzeb FLUENT 5 August 3, 2004 09:04
Compressible flow problem Lewis FLUENT 2 July 11, 2004 08:29
