Can a boundary layer trip wire change the Reynolds number? |
January 30, 2015, 17:11 |
Hi all,
I am wondering, if we have a problem with a simple fixed uniform flow speed against an object (for example airfoil), with the dimensions and shape of the object remaining fixed. Does including a boundary layer trip wire, vortex generators etc actually change the Reynolds number in the analysis of the problem? Or would you say that at the same Reynolds number as before, we found a way to alleviate the boundary layer effects/create more turbulence in the boundary layer etc. Thanks for your time! |
February 2, 2015, 05:21 |
spl
Rep Power: 12 |
No the Reynolds no. would remain constant. The trip wire just 'trips' the boundary layer and causes transition giving a turbulent boundary layer at lower flow velocities. It is done to allow wind tunnel tests, where the Reynolds number is lower than the real life application to be more representative of the real case. And as for vortex generators, they cause the momentum with in the boundary layer to be redistributed to delay flow separation. Again this wouldn't effect Reynolds number as the flow velocity and chord length of the aerofoil remain constant. I'm not sure what you mean by alleviate boundary layer effects? Regards |
February 2, 2015, 08:11 |
Filippo Maria Denaro
Rep Power: 73 |
Thinking about the question, if you consider the local Re number along the wing (somehow similary to considering the local Re number along a flat plate), the induced perturbation in the velocity can have some effect.
I am not able to say if that effect is also really relevant... |
February 2, 2015, 10:55 |
spl
Rep Power: 12 |
Hi Filippo
I agree that the trip would create protrusions in the flow. However both trips and vortex generators focus on the flow within the boundary layer. The boundary layer will therefore be effected but if you were to calculate the local Reynolds number you would use the local velocity at the edge of the boundary layer. Therefore, shouldn't the the local Reynolds no. still be unaffected? |
February 2, 2015, 12:20 |
#5 | |
Rep Power: 73 |
to tell the truth, I don't know...I was thinking if somehow the trip should be considered as the new starting-edge of the boundary layer... But I suppose that should not be relevant in a CFD simulation if you consider the cell-Reynolds number of the y+ (which is also a local Re number). |
February 18, 2015, 03:14 |
About Trip wire
Arun
Rep Power: 14 |
I'm just lost in the "trip wire" May i know what is that. I understand vortex generator but trip is something that do the same?
February 18, 2015, 04:41 |
spl
Rep Power: 12 |
A trip wire is used to "trip" the flow to give a turbulent boundary layer. Its usually used in wind tunnel testing where the Reynolds number of the test is lower than the real case. At the lower test Reynolds number natural transition may occur much later over the model leading to inaccuracies. If you use a trip wire along, or near to the leading edge, the boundary layer will transition just after the trip. This alleviates some of the errors due to scaling.
boundary layer, reynolds number, tripwire |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 11:27 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 14:20 |
