Face based gradient calculation
Old   February 12, 2008, 06:19
Default Face based gradient calculation
Bernhard Kubicek
Hello! I am currently implementing the face based gradient calculation into a custom solver, very similar to the description in the wiki pages. However, I noticed that some Fluent meshes contain elements whose faces are non-plain. This creates troubles while calculating a good normal vector, and the gradient calculation is very wrong even with slightly non-flat faces. Currently, I define the normal vector as the mean of the opposing corners normal vectors (nodes 1,2,3,4: 0.5(21x23+43x41) )
Is there a more elaborate system of doing this?
Very nice greetings, and thanks a lot Bernhard
(Just for information, I use a face value that is calculated using the different material properties of the individual cells.)
Old   February 12, 2008, 17:34
Default Re: Face based gradient calculation
Ananda Himansu
split the face into triangles? each triangle has a unique normal vector.
Gradient calculation in CFX appu CFX 1 May 28, 2011 07:48
gradient calculation in unstructured grid gray053 Main CFD Forum 1 February 27, 2011 20:26
Gradient of Scalar calculation in 3D BFCskew grids james T Phoenics 0 March 28, 2007 08:12
Calculation of face vaules with udf rom FLUENT 0 November 3, 2005 03:04
calculation of velocity gradient at a cylinder per chaitanya FLUENT 0 February 4, 2002 03:06
