Batch job
Old   February 11, 2008, 13:49
Default Batch job
M. Malik
After submitting a batch job on the SGI machine, the job gets killed as I close the window. I remember once there was a posting on this issue and solutions were suggested. I don't remember that now. Will appreciate your suggestions to get rid of this problem. Thanks.
Old   February 11, 2008, 16:43
Default Re: Batch job
ag
I don't remember the detail for the SGI but you want to run your job in the background. Try executing your job using "jobname &". Or just don't close the window (which won't work if you have to share the machine with others.
Old   February 11, 2008, 17:37
M. Malik
Thanks. Actually that's the way I do it (i.e. jobname &). Any other thoughts that the batch job may keep going after closing the window or even logging off?
Old   February 11, 2008, 17:41
Kyle
This is so not the way you SHOULD do it, but what I do is submit the job from a VNC session running on the cluster. That way when you close the window it kill the process, just closes your VNC connection.
The best thing you could do would be to install a queuing system that submitted your jobs for you.
Old   February 11, 2008, 17:42
Kyle
sorry that should read "That way when you close the window it DOES NOT kill the process, just closes your VNC connection."
Old   February 11, 2008, 18:58
topea
Do you launch the job with nohup ?
Old   February 12, 2008, 10:49
M. Malik
Thanks Topea, Kyle, and ag. It works with nohup (nohup execute &).
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 05:16
FLUENT Batch job Saravanan FLUENT 11 May 14, 2014 17:47
[Question]About batch job fluboy FLUENT 2 August 12, 2009 12:10
Running Job in Batch mode (EFD) Nick Sessions FloEFD, FloWorks & FloTHERM 0 April 16, 2008 17:44
transient job via LSF, batch job Etienne FLUENT 2 April 5, 2006 15:50
