Re: Convergence problem for refined grid
Old   February 11, 2008, 13:28
Default Re: Convergence problem for refined grid
CFD_Novice
I wrote a 2D CFD code using SIMPLE on collocated grid. I test the code with some simple cases. I found that when the grid is coarse, the solution agrees with the theoretical solution. When I refine the grid, the solution becomes divergent. So what is wrong with my code? How can I improve the convergence?
Thank you for any help.
Old   February 11, 2008, 21:59
alpha
Are you solving RANS equations on your grid. If yes, how dense was your grid? If you use both infinitely fine grid and turbulence model then you are bound to have problems, because you will be solving reynolds stresses directly and your turbulence model will also take into account effects of turbulence in your flow field. Therefore, you end up with wrong results.
alpha
Old   February 12, 2008, 00:07
CFD_novice
Thank you for your answer. Currently, I am only considering Laminar flow and solving a simple flow problem which has theoretical results. The numerical solution with 5 X 5 grid agree well with the theoretical one. However, when I refine grid from 5 X 5 to 60 X 60, the result is even not convergent.
Any input will be appreciated.
Old   February 12, 2008, 08:42
alpha
What i dont understand is why would you refine your grid to this extent for a laminar flow. What sort of Reynolds number are you working on? If boundary layer is laminar there is no need for DNS type grid resolution, a coarse grid will be fine.
alpha
Old   February 12, 2008, 09:49
student
Brief you problem definition, method used,
Old   February 12, 2008, 14:15
agg
Looks like you are not conserving mass, maybe because of your numerical scheme. This doesn't show up on a coarse grid, but does when you refine. I assume you are solving incompressible flow. Compute du/dx+dv/dy for each cell, for the coarse and fine simulations (for each time step and see if you are maintaining a divergence-free velocity).
Old   February 12, 2008, 14:32
CFD_novice
Response to Alpha,
Thank you for your quick response. I agree with you that for laminar flow, coarse grid works fine. In fact, I encountered divergence problem when I calculate turbulent flow (Re =4000) with my code. I can not figure out why. So I go back check my laminar flow simulation. I found that if I use fine mesh, there is some convergence problem even for laminar flow. Therefore, I think I need to solve the divergence problem for laminar flow then go to turbulent flow.
Old   February 12, 2008, 14:42
CFD_novice
Hello agg,
I use SIMPLE method on collocate grid. The numerical scheme is UPWIND. To test my code, I use several simple laminar flow cases. For example, flow inside a square container with a moving lid. They show some divergence problem when the grid becomes finer, more or less.
Thank you.
Old   February 12, 2008, 14:53
CFD_novice
I will check the mass conservation and get back to you later.
Thanks.
Old   February 12, 2008, 18:43
CFD_novice
I solve the pressure correction equation derived with mass-conservation equation. Is there any way to measure how well the mass conversation is satisfied when the grid becomes finer?
Thank you.
Old   February 13, 2008, 00:05
  #11
santo
Pressure oscillations plays an important role in colocated grid. Have you used Rhie and Chow interpolation to avoid this problem for calculating mass flux.
continuity eq is your convergence criteria du/dx + dv/dy =0 on integrating over a C.V yields (u_e-u_w)dely + (v_n-v_s)delx=0 here one has to apply Rhie and Chow interpolationss for calculating flux velocities.
Please correct me if I am wrong.
San
Old   February 13, 2008, 00:34
  #12
quarkz
Speaking from my own personal experience, if everything else is correct (scheme,Rhie and Chow interpolation etc), most likely you have a careless mistake. You may need to inspect your code.
Btw, you should also check when and where does it diverge. Is it due to momentum or poisson eqn?
Hope that helps...
Old   February 15, 2008, 14:39
  #13
CFD_Novice
Thank you all for suggestions. I did find several careless mistakes when inpsecting the code. But it is frustrating to see that the result doesn't have obvious improvment. To avoid the pressure's osillations on collocated grid, I utilize A.W. Date's method, not Rhie and Chow's interpolation.
The paper for this method is "Complete pressure correction algorithm for solution of incompressible Navier-Stokes equations on a nonstaggered grid" by A.W.Date, Numerical Heat Transfer B, Vol.29,1996
Do you have any comment on the difference of this two methods?
Cheers,
Old   February 17, 2008, 23:56
Default SUMMARY
  #14
CFD_novice
I finally overcome the divergence problem for the refined grid on Laminar flow. The reason is that the careless mistakes I made in my code. Hope that it will be helpful when others encounter similar problem.
Thank you all for help.
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Need URGENT HELP for convergence problem of a turbine Pursuor CFX 5 October 3, 2011 18:44
Continuity eq convergence problem carno FLUENT 4 February 8, 2008 05:04
Grid Independence problem for simple pipe geometry chanchala FLUENT 13 November 20, 2003 09:24
convergence problem Trushar Phoenics 5 August 28, 2002 00:40
