help with the mixture pressure in Eulerian Model |
January 22, 2015, 05:10 |
Jas
Rep Power: 16 |
For Eulerian Model, what's the meaning of the static pressure of mixture. In the results-reports-surface integrals, I found the static pressure of mixture was much larger than that of fluid (considering the effect of dynamic pressure). In my opinion, the mixture in Eulerian Model should have no physical meaning and they should have the same value. Appreciate for your help! Best regards, socreate Last edited by socreate; January 22, 2015 at 05:16. Reason: polish language |
mixture eulerian |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
mixture mass continuity v.s. volumetric mixture continuity in pressure equation | kaifu | OpenFOAM | 0 | June 9, 2011 09:14 |
A question about UDF utility in mixture and multiphase model | aleisia | Fluent UDF and Scheme Programming | 0 | June 7, 2011 17:32 |
can we use same udf for mixture n eulerian model | Rashmi | FLUENT | 1 | March 28, 2006 17:32 |
