How to get the mean values of the unsteady flowfield?
Old   January 22, 2015, 03:28
Default How to get the mean values of the unsteady flowfield?
Stone4688 is on a distinguished road
I'm using CFD++ 14.1 to complete the computation of an unsteady case. And I want to get the mean values of the entire flowfield to describe the mean flow, namely, the velocities and Cp. My purpose is to make a picture of the streamlines and the contour of Cp in Tecplot. What should I do with CFD++ settings?
New to CFD++, looking forward to any help.
Stone4688 is offline   Reply With Quote
Old   January 24, 2015, 03:35
Default New progress
Hi guys, I'm not sure if anybody is familiar with CFD++ and know the solution to this question.
I try it again and find that I can get the time averaged solution restart file(SRF). And it is available to convert neutral plotting file(NPF) to Tecplot file.
But if there is any way to convert SRF to NPF???
I tried to simply change the name, but it doesn't work.
It's kind of driving me mad.
Old   January 30, 2015, 08:04
Simm
kulls is on a distinguished road
You can get mean values of cp using CFD++ at any defined constant plane
Thanks!!
kulls is offline   Reply With Quote
Old   February 2, 2015, 03:50
Thank you for your help! I've found the proper way to get the Tecplot file.
Old   June 17, 2015, 01:34
Default Converting SRF(cdepsout.bin)-Tecplot files.
Nishant
Nishant Soni is on a distinguished road
Hello Stone,
I am facing the same problem what you've mentioned. How did you sort it out. Can you please tell me about it.
Thanks.
Nishant Soni is offline   Reply With Quote
cfd++, mean flow field, tecplot 360, unsteady flow
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
mean values in unsteady data Usman FLUENT 0 February 24, 2009 07:28
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 13:04
node values or cell values? aPpA FLUENT 0 November 10, 2006 09:56
Plotting raw data values Wilesco Siemens 0 January 5, 2006 06:34
