Hi all,
I'm very interested in developing a high order finite volume scheme ( order 3 or 4) for incompressible flows on unstructured meshes. Could you give me some references ? Thanks in advance. |
high order unstructured schems is basically difficult to implement due to extended stencil, but there are some compact methods.
i suggest cubic spline based methods (both field and its derivatives are considered to construct method), for this look at recent publications of Feng Xiao (in JCP and CPC), e.g. : Unified formulation for compressible and incompressible flows by using multi-integrated moments II: Multi-dimensional version for compressible and incompressible flows, JCP CIP/multi-moment finite volume method for Euler equations: A semi-Lagrangian characteristic formulation, JCP A 4th-order and single-cell-based advection scheme on unstructured grids using multi-moments, Computer Physics Communications 173 (2005) 17â€"33 |
Thanks, rt.
High order elements | pankos | Main CFD Forum | 1 | February 1, 2011 08:56 |
High order finite volume schemes | DoHander | Main CFD Forum | 5 | January 19, 2010 00:59 |
divergence with higher order scheme | shekharc | Main CFD Forum | 1 | July 23, 2009 13:53 |
High resolution scheme??? | vijay | CFX | 1 | April 22, 2008 09:37 |
High order difference scheme for KIVA3v2??? | LiQiang | Main CFD Forum | 1 | May 9, 2005 13:50 |
