Can someone recommend a mature and robust grid reordering algorithm?
Old   January 14, 2015, 09:49
Default Can someone recommend a mature and robust grid reordering algorithm?
Sheldon Lee
Sheldon Lee is on a distinguished road
I am developing a LU-SGS code now, and is searching for a appropriate reordering method.
Is there anybody with rich experience of grid rerodering ?
many thank!
Sheldon Lee is offline   Reply With Quote
Old   January 14, 2015, 13:41
Michael Prinkey
mprinkey will become famous soon enough
I've done grid re-ordering with Reverse Cuthill-McKee. Also, I've done it (along with parallel partitioning) using Hilbert Space Filling curves. The former uses only graph information, while the latter uses geometric data. And, as chance would have it, I was reading this paper last night:
http://www.jpier.org/PIERL/pierl09/04.09042305.pdf
RCM seems to be the most commonly used. The GPS scheme and variants in the paper are less robust but deliver better reduction. Space-filling curves come at the problem from a different direction, but can be quite useful, especially if you need to sort cells, faces, edges, and/or nodes to access all of them together efficiently.
EDIT. I should also note that space-filling curves may not always provide absolute minimum bandwidth. They tend to give good bandwidth reduction on most rows with a handful of outliers that could have large bandwidth. For cache optimization, it still works reasonably well...a few misses will always occur and so it is more the average cache hit rate that matters in those situations. But for schemes that do require absolute reduction (say to prevent large amounts of fill-in for direct solvers), RCM or GPS are a better choice.
mprinkey is offline   Reply With Quote
Old   January 20, 2015, 04:38
Sheldon Lee
have you used the RCM method along with the lu-sgs or gmres? Is the effect obvious?
Old   January 20, 2015, 15:10
Michael Prinkey
Sorry, no. I've never done anything with lu-sgs. I've use GMRES for linear systems, but never with grid re-ordering.
reordering
